AndrewDraws Posted January 24, 2025 Share Posted January 24, 2025 I am creating some layout drawings for a renovation. The house has siding on the exterior. I find all the horizontal lines of the siding distracting when including dimension lines, so I would like to hide the external layer. However, I can't find anything in lays like Walls, External. How can I hide the exterior wall material, without going into each wall and changing the material? I'm using Home Designer Pro 2024 Many thanks! Link to comment Share on other sites More sharing options...
AndrewDraws Posted January 24, 2025 Author Share Posted January 24, 2025 After asking this question and digging a little deeper, I realized that if I hide the external cladding the internal framing would be visible. So, any thought on how to deal with this situation? Link to comment Share on other sites More sharing options...
Solution solver Posted January 24, 2025 Solution Share Posted January 24, 2025 You are asking about Patterns. You want to turn off the display of patterns. Open Help and search patterns. you will find your answer with a bit of reading. Link to comment Share on other sites More sharing options...
AndrewDraws Posted January 25, 2025 Author Share Posted January 25, 2025 Thanks Eric, that is just what I was looking for. Appreciate the help. Andrew Link to comment Share on other sites More sharing options...
