Chill1212 Posted January 4 Share Posted January 4 Hi guys quite common in the uk currently with my carpentry work to install units like these under stairs or up against roof eaves in lofts. I’m fairly competent in using hd now but can’t work out a way to make a cabinet angled either for the loft eaves so sloped at the back or sloped left to right or right to left. Looked everywhere! Please help. Link to comment Share on other sites More sharing options...
solver Posted January 4 Share Posted January 4 2 hours ago, Chill1212 said: I’m fairly competent in using hd now Always mention what software you are using -- Pro, Architectural or Suite, and the version (year). Not even the Chief Architect products are able to do what you want simply. For the cabinets in the first picture, use shallow cabinets to get the fronts and to keep the backs from sticking through the roof. For the under stair units, it depends on the door style. You can sometimes use a passage door with a Tudor Arch. Also a Custom Backsplash can be used in creative ways -- search the forum for ideas. Link to comment Share on other sites More sharing options...
