Set up Toolbar
sharedjourneys
I'm using Home Designer Pro 2025. Upgraded computer and reinstalled HPD25 software. The Toolbar previously remembered last action used. Example: If I am using "Wall Elevation" and move to Dimension something....then moved back to "Orthographic Tools" it's not remembering last action i.e. "Wall Elevation." The first tool on the list is checked not the last tool used. It's not remembering "last action." I can't find where to set this up. Help is greatly appreciated.
Thanks so much,
Michele Lessirard
  On 12/30/2024 at 4:18 PM, sharedjourneys said:
I figured it out by watching the training video. Preferences > Appearance>Toolbars and click "dropdown" to remember last action.
Expand
Chief always will select last action used regardless of using the tool palette or the drop down menu. There is no option to change the behavior of last object used. Was it just that you wanted the drop down menu?
