PhilCrane Posted November 16, 2024 Share Posted November 16, 2024 I am running HDS Architectural 2025 and am trying to add some blinds to my windows. I go into the Library Browser and look for blinds and have selected the vertical 24" blind. I can select it and click on my window to apply the blind but, for the life of me, I cannot work out how to select the blind to change it's size (it always seems to be shorted than the length of the window). Whenever I click on the blind it always selects the window, I've tried using the Tab key to select the next object but that doesn't work either. I've tried this in the Cross Section/Elevation view and also in Camera view without luck. Any ideas? Thanks Link to comment Share on other sites More sharing options...
solver Posted November 16, 2024 Share Posted November 16, 2024 1 hour ago, PhilCrane said: and am trying to add some blinds to my windows Blinds are typically applied through the window dialog. They will automatically resize to fill the window. If you click on a blind in the Library Browser, then click on a window to apply it, it gets applied as a curtain. If you click on a wall, it gets applied as a stand alone fixture that you can manually move into place, and resize as needed. Link to comment Share on other sites More sharing options...
