PhilCrane Posted November 5 Share Posted November 5 Hi, I am running HDS 2025 and have hit a problem when trying to paint rooms that contain a room divider. I have attached a simple plan where I used a room divider to have one side with an 8' ceiling and the other side with a 12' ceiling. When I paint the rooms I notice 2 problems. Firstly, a small strip where the room divider is always comes out as white and I cant find a way to stop this - not a big problem, maybe a software issue? More importantly though, I cannot find a way to paint the wall between the rooms where it drops from 12' to 8'. Does anyone know how to do this please? Maybe I should be using something other than a room divider.... Thanks Painting.plan Link to comment Share on other sites More sharing options...
solver Posted November 5 Share Posted November 5 3 hours ago, PhilCrane said: Firstly, a small strip where the room divider is always comes out as white Using your plan opened in Pro 2025, I painted the strip -- or the 2 strips that were there. 3 hours ago, PhilCrane said: Maybe I should be using something other than a room divider.... The Room Divider gets converted by the program to an interior-4 wall. In Pro, it paints without a problem. I don't have Suite 2025 to test, but it should work the same. Link to comment Share on other sites More sharing options...
PhilCrane Posted November 5 Author Share Posted November 5 May I ask how you painted them please? Link to comment Share on other sites More sharing options...
PhilCrane Posted November 6 Author Share Posted November 6 Thank you so much, that was extremely helpful. I had only been selecting either a room or a wall and painting it so using the Material Painter helped enormously. Thanks. Link to comment Share on other sites More sharing options...
