Baandit Posted August 30, 2024 Share Posted August 30, 2024 I am building a new house and my design uses gable roofs. There are two(2) places where I have cathedral ceilings where parts of the cathedral ceiling are under parts of other roofs. My problem is I want to maintain the framing and ceiling of those roofs but do not want the roofing material on those sections of the roof that are under another section of roof. The attached picture should show my dilemma. the 1st picture shows the portion under another gable and the 2nd picture shows the portion outside the other gable. Thanks in advance for any help on this, Link to comment Share on other sites More sharing options...
solver Posted August 30, 2024 Share Posted August 30, 2024 2 hours ago, Baandit said: My problem is I want to maintain the framing and ceiling of those roofs but do not want the roofing material on those sections of the roof that are under another section of roof. You don't want to see the sheathing and shingles? Link to comment Share on other sites More sharing options...
Baandit Posted August 30, 2024 Author Share Posted August 30, 2024 Yes, but only on the part of the roof that is inside (or covered by another section of roof). it would be nice if you could split the roof into sections. Link to comment Share on other sites More sharing options...
solver Posted August 31, 2024 Share Posted August 31, 2024 1 hour ago, Baandit said: it would be nice if you could split the roof into sections. You may create separate roof planes with Pro. Tip: Always say what software you are using, like Pro 2024, as many suggestions depend on knowing this. Link to comment Share on other sites More sharing options...
Baandit Posted August 31, 2024 Author Share Posted August 31, 2024 I am using Pro 2024. Can you split an existing roof plane in two? Link to comment Share on other sites More sharing options...
solver Posted August 31, 2024 Share Posted August 31, 2024 4 hours ago, Baandit said: I am using Pro 2024. Can you split an existing roof plane in two? No, but you can copy in place and reshape to create separate roof planes. Link to comment Share on other sites More sharing options...
