btushaus Posted August 13, 2024 Share Posted August 13, 2024 I am a newer user to Home Designer and I am using Architectural 2025. I am having trouble getting a gabled roof to work correctly and I have searched the KB and this forum and can't find my answer. The attached image show what I am trying to do and my problem. The gable that is coming up from the setback garage portion should meet at a peak the gabled roof coming from the other direction. I have the roof option for the front garage wall set to "Full Gable Wall" and the setback garage wall set to "Dutch Gable Wall". But, again, I have not been able to determine how to complete the gable where it naturally meets at the peak. I would very much appreciate any guidance anyone could provide. Thank you. Link to comment Share on other sites More sharing options...
btushaus Posted August 14, 2024 Author Share Posted August 14, 2024 Thank you solver for the quick reply. Plan attached here. Sophia4.plan Link to comment Share on other sites More sharing options...
Garybills Posted August 14, 2024 Share Posted August 14, 2024 @btushaus I looked at your plan and I don't think you can get the roof to build in HDA without being able to manually edit the roof planes. Someone else may know a way but it looks like Home Designer Pro would be needed. You could try and get someone with HDP or Chief Premier to fix the roof and send the plan back to you. Link to comment Share on other sites More sharing options...
Jo_Ann Posted August 14, 2024 Share Posted August 14, 2024 Because I can't look at your plan file, and because you only posted a partial floor plan pic, I am guessing at what you want, in HDA program. Is this what you are trying to do? Link to comment Share on other sites More sharing options...
btushaus Posted August 14, 2024 Author Share Posted August 14, 2024 Jo_Ann, yes, that is exactly what I am trying to accomplish. I did post the plan in my second post above after solver suggested it...if that helps at all. Thank you so much for taking a look at this. Link to comment Share on other sites More sharing options...
Garybills Posted August 15, 2024 Share Posted August 15, 2024 @btushaus After @Jo_Ann posted I had to try again. I got the front, but the back gets close with a hip on the end. If I change it to a Gable, it makes brings back the strange looking gable wall. Maybe Jo-Ann can figure out the back with the rest of the plan. Link to comment Share on other sites More sharing options...
Garybills Posted August 15, 2024 Share Posted August 15, 2024 @btushaus If you're not able to get everything to work, attached is a copy of your plan I fixed the roof in Chief, and it can be edited in HDA. Just remember you can't edit the roof and if you turn on auto roofs you will loss what I did. good luck. Sophia4 edit.plan Link to comment Share on other sites More sharing options...
Jo_Ann Posted August 15, 2024 Share Posted August 15, 2024 There have been no pics posted of what the back roof is supposed to look like. Based on the more complete floor plan that Garybills posted, I created this. Of course I have no idea what the roof pitches are, so it is still all a big guessing game. 1 Link to comment Share on other sites More sharing options...
Solution Jo_Ann Posted August 15, 2024 Solution Share Posted August 15, 2024 corrections made Link to comment Share on other sites More sharing options...
btushaus Posted August 15, 2024 Author Share Posted August 15, 2024 Jo_Ann, thank you SO much...this gave me exactly what I needed. Much appreciated! Link to comment Share on other sites More sharing options...
davidmurray Posted August 20, 2024 Share Posted August 20, 2024 I have a similar problem with a Dutch Gable roof at the rear of my home. HD Studio is defaulting to a Gable roof and I can't change it. Link to comment Share on other sites More sharing options...
davidmurray Posted August 20, 2024 Share Posted August 20, 2024 Attached is my plan file. 08-20-2024 - 3443 Curlew Dr -NOH2O- Water Wise-Adaptive.plan Link to comment Share on other sites More sharing options...
Garybills Posted August 21, 2024 Share Posted August 21, 2024 @davidmurray select the back deck railing and open the roof specification and mark it as Dutch Gable. Link to comment Share on other sites More sharing options...
