DaveRegis Posted July 22, 2024 Share Posted July 22, 2024 If you create a new "Pony Wall", it includes a pony wall cap -- a molding which sits atop the pony wall. If you edit an existing (regular) wall, and check the "Pony Wall" box in Wall Types, it allows you to specify the lower wall type and other attributes as expected. However, it doesn't add a pony wall cap -- and I don't see any way to specify one. It seems like this would be specified in Moldings, but that specification category isn't available. So, there are two issues I'm up against: Conversion of existing normal walls to pony walls mostly works, but I don't see a way to add a cap When creating a new pony wall, I don't see any way to change the cap molding size or style Am I missing something? Link to comment Share on other sites More sharing options...
Solution DavidJPotter Posted July 22, 2024 Solution Share Posted July 22, 2024 The features you wish do not exist in any Home Designer title; they do exist in Chief Architect Premier, sorry. DJP Link to comment Share on other sites More sharing options...
DaveRegis Posted July 22, 2024 Author Share Posted July 22, 2024 37 minutes ago, DavidJPotter said: The features you wish do not exist in any Home Designer title; they do exist in Chief Architect Premier, sorry. DJP Thanks for the reply! Not the answer I was hoping for -- still, I'm continually impressed at the capabilities that are available in the non-Chief line-up. Link to comment Share on other sites More sharing options...
