mhogan Posted June 5, 2024 Share Posted June 5, 2024 (edited) I'm working on designing the interior of my existing basement. I've got the footprint complete and now I need to show the existing 3x3 steel columns in their existing locations. I can't find any column objects that fit to place these. Any advice? Edit: I'm using Home Designer Suite 2024 Edited June 5, 2024 by mhogan Forgot to state what verision I'm using Link to comment Share on other sites More sharing options...
Solution Garybills Posted June 5, 2024 Solution Share Posted June 5, 2024 This is Suite 2023. Try using a cylinder from the core catalog, shapes, cylinders. There may be another way but that's all I could find. 1 Link to comment Share on other sites More sharing options...
y-g-m-n Posted June 5, 2024 Share Posted June 5, 2024 they have box shapes and then just change dimensions to suit. Not sure what they have in library but I see plain square columns under: HD Core - Architectual - - Millwork - - - Columns - - - - Basic (does have top and bottom band but should work) There is an entire library under manufacturers: DEAN COLUMN COMPANY I tried to find it on HD library page but could not so I am attching.: Dean Column Co. Inc..calibz Link to comment Share on other sites More sharing options...
mhogan Posted June 6, 2024 Author Share Posted June 6, 2024 Thanks for both responses. I was unable to find the "Basic" column in the library even after updating. I was able to create a cylinder and resize it to show the columns on the plans. 1 Link to comment Share on other sites More sharing options...
y-g-m-n Posted June 7, 2024 Share Posted June 7, 2024 did you not download the DEAN COLUMN library? It has everything. Link to comment Share on other sites More sharing options...
