CharlieC Posted March 31, 2024 Share Posted March 31, 2024 I have an older version of Home Designer Suit (2014) that I used before retiring from building . I recently decided to create some preliminary plans for a house for myself but ran into a problem using the interior dimension tool. Every once in awhile, it works but 95% of the time it does not. I select the interior dimension from the dimension tools, click on the first wall, drag line to next wall and release but no dimension appears. Can anyone suggest what this might be caused by. Thank You Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 1, 2024 Share Posted April 1, 2024 The dimension tools have not changed or added to in HD or Chief since at least the year 2,000 AD. You do have to make them work from time to time. There several measurement tools to use so when one works or another automatic tool fails you just use one you can make work. DJP Link to comment Share on other sites More sharing options...
