krimco1 Posted March 10, 2024 Share Posted March 10, 2024 A few roofing issues I can't figure out... 1. How do I fix the gable of the second floor that overhangs so it's an extension of the main roof (See photo of actual house)? 2. How do I lower the roof of the porch without lowering the floor of that second floor overhang? 3. How do I fix the wonky gable roof extensions over the porch and garage? My plan is bigger than 14 MB so here's everything at a dropbox link - https://www.dropbox.com/scl/fo/nm8nax6j2imyt8blhu6d6/h?rlkey=bs2kq39g8krskd4cttoiott0e&dl=0 Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 11, 2024 Share Posted March 11, 2024 Your edited plan file is attached below. DJP DJP.zipFetching info... Link to comment Share on other sites More sharing options...
Jo_Ann Posted March 11, 2024 Share Posted March 11, 2024 This example was done using only the tools that Suite has. 1 Link to comment Share on other sites More sharing options...
krimco1 Posted March 11, 2024 Author Share Posted March 11, 2024 On 3/11/2024 at 6:47 PM, Jo_Ann said: This example was done using only the tools that Suite has. Expand @Jo_AnnWould love the details on how if you don't mind. Thank you! Link to comment Share on other sites More sharing options...
krimco1 Posted March 11, 2024 Author Share Posted March 11, 2024 Thanks @DavidJPotter! Was hoping to avoid turning off auto build roofs but will do this if all else fails. And sorry I didn't include all the details. But the porch is a planned addition. Does not currently exist. Also my first floor and porch are not at ground level. They are 16in off the ground. I'm mid-design on the porch so ignore the elevated slab. It's actually a deck. Link to comment Share on other sites More sharing options...
Jo_Ann Posted March 11, 2024 Share Posted March 11, 2024 This is a re-creation based on the floor plan you posted a long time ago. So, dimensions are not accurate, and ceiling heights are guesses. Auto Rebuild Roof is still turned on in the this plan. You should be posting in the Q&A category. If you still have the Suite file, it would be helpful if you uploaded the plan file in Q&A. Link to comment Share on other sites More sharing options...
