ChiefUser6767 Posted February 25, 2024 Share Posted February 25, 2024 This is probably very simple, but I can't figure it out ... : After creating my flat roof, I wanted to drop the ceiling height for some sections of the home. I'd like for the space above the dropped sections to become a 4' attic/ vented crawlspace. How can I maintain a level flat roof line, while also dropping the ceiling underneath? Here's a pic Thank you! Link to comment Share on other sites More sharing options...
y-g-m-n Posted February 26, 2024 Share Posted February 26, 2024 ONe trick is to insert a FLAT ceiling plane in those rooms you want at the desired lower height This should hold the roof flat and one height while also giving you the lower ceiling height. Might want to turn off THIS ROOM HAS FLAT CEILING to open it up to attic above this new ceiling plane. I am sure there is another way by setting the each room's ceiling height that is not DEFAULT to whatever you want and then there are some controls to raise wall heights to make roof soffit/fascia all one height - But I have not done that so I am no help with what to click on this method other then check your HELP screens Link to comment Share on other sites More sharing options...
