redraz Posted November 14, 2023 Share Posted November 14, 2023 Seeking help with manually added ceiling planes for an attic space (no I do not have them as "attic" in the program) - I cannot figure out where I have gone wrong - 1. I have sections of ceiling going through the roof for some reason, when I try to correct, the handles aren't there to move or adjust them. 2. The next issue is a portion of one of the plane is showing as black on the physically based camera - but only a portion of it. 3. I cannot get the ceiling to connect over the tub area - the walls here actually fan out to meet each other, I just need to create a similar look for the renovation. ***perimeter walls are 60" with the exception of the wall with the entry door, ceilings are 99.5" at flat portion and the area over the tub which is 71" ***video card is good Untitled1.zipFetching info... Link to comment Share on other sites More sharing options...
redraz Posted November 15, 2023 Author Share Posted November 15, 2023 On 11/15/2023 at 12:09 AM, solver said: Close Pro before you zip the plan. Expand Good to know! Untitled1.zipFetching info... Link to comment Share on other sites More sharing options...
solver Posted November 15, 2023 Share Posted November 15, 2023 Link to comment Share on other sites More sharing options...
redraz Posted November 15, 2023 Author Share Posted November 15, 2023 On 11/15/2023 at 3:20 PM, solver said: Expand Hi Eric, Thank you so much for your fixes here! I would love to know how to fix the gaps in the ceiling that you pointed out as well. I have also attached a photo of the area over the tub that I was (unsuccessfully) trying to replicate for reference. Again, thank you so much! Link to comment Share on other sites More sharing options...
redraz Posted November 15, 2023 Author Share Posted November 15, 2023 I meant to add that when I try to repair the roof - I am assuming you are using the join roof planes tool - but I keep getting this error Link to comment Share on other sites More sharing options...
solver Posted November 15, 2023 Share Posted November 15, 2023 On 11/15/2023 at 3:59 PM, redraz said: I would love to know how to fix the gaps in the ceiling that you pointed out as well. Expand The ceiling in the alcove seems to be sloped in your image, but you have drawn it as flat in your model. With a sloped ceiling, it will join with the other ceiling planes and eliminate the gap. On 11/15/2023 at 4:38 PM, redraz said: but I keep getting this error Expand Watch what roof edge I select when joining -- you need to select the 2 edges, not just the 2 roof planes. Link to comment Share on other sites More sharing options...
