creating panel moldings on staircase wall
Donco15
Hi Guys
I am trying to create panel molding design on a staircase wall  with a mirror inset a few things I have run into
Since this is the staircase wall you cant do an elevation to showcase the entire wall.  I only get a portion of the wall..
After creating my mirrors and exact locations, I could not find a way to create a panel molding effect
I used the soffit tool and tried to do it manually, but it really is not the right way to do this to get the desired effect
I found a video showing a method for chief architect, but I know there must be a simple way to do this in Pro 2023
Thanks for your help in this matter in coming up with a solution.
ERIC
THANKS FOR THE VIDEO
QUESTION
HOW DO I GET MY STAIRCASE TO SHOW SO THAT I GET THE FULL PERSPECTIVE VIEW WHERE I CAN USE CAD LINES?
WHEN I DO AN ELEVATION IT ONLY SHOWS PARTIAL WALL
I USED THE SOFFIT TOOL SO THAT I CAN SHOW SOMETHING TO THE CARPENTER AND CLIENT
I WILL TRY USING THE METHOD IN YOUR VIDEO
THIS WAS JUST A ROUGH VISUAL TO  SHOW THEM MY ROUGH IDEA FOR THE STAIRCASE WALL DESIGN
THX FOR THE VIDEO
