augusdo63 Posted August 24, 2023 Share Posted August 24, 2023 I use Home Designer Architect 2024. When I create a two story porch and then place windows on the second floor (under the porch roof) the windows do not show up on the perspective view . I have found that I can place them on the first level and drag them up to the approximate place. When I do that I can see both windows on the perspective view. Please help. Link to comment Share on other sites More sharing options...
solver Posted August 25, 2023 Share Posted August 25, 2023 17 minutes ago, augusdo63 said: When I create a two story porch Don't do that. Instead, use a normal (default) room height on the first floor, and create a same size room on the 2nd floor with the Open Below room type. 1 Link to comment Share on other sites More sharing options...
augusdo63 Posted August 25, 2023 Author Share Posted August 25, 2023 2 hours ago, solver said: Don't do that. Instead, use a normal (default) room height on the first floor, and create a same size room on the 2nd floor with the Open Below room type. Won't that create two sets of columns? Link to comment Share on other sites More sharing options...
solver Posted August 25, 2023 Share Posted August 25, 2023 25 minutes ago, augusdo63 said: Won't that create two sets of columns? Probably. I imagine you will need to place your own columns. Architectural is limited in many areas. Is this similar to what you are modeling? Done in Chief Premier (all automatic), could be done in HD Pro too. 1 Link to comment Share on other sites More sharing options...
