railing ends buried in wall and roof line
sactown
Unfortunately I'm stumped on this one. The ends of my deck railing need to move away from the deck corners so they aren't buried inside the walls and roof. Here's some pictures to help explain.
Some notes:
-This is a first story deck elevated to tuck under the 2nd story cantilever.
-I customized the framing to put the beam at the same level as the joists
-I'm using HD Pro 2024
What I've tried:
-If I move the railing away from the wall, the deck disappears (probably since it is no longer attached to the house).
-In Deck Railing Specifications - Rail Style - Start/End Posts: I've tried every combination along with Start Wall and End Wall Offsets but that doesn't move them.
Any help appreciated.
11 hours ago, Rookie65 said:
Try breaking the railing and making the section invisible
Thanks! I think your username needs an upgrade to expert, that was a brilliant fix. Never crossed my mind to wall break a railing, so much to learn. Thanks again!
