Can I modify an object in the library browser?
attorianzo
Hi, I need to modify an object in the library browser.
In particular I need a fireplace with three fronts instead of two (the one in the library.
Can I export that object in order to modify it with another 3D software and import back to Home Designer Pro?
Very vague description of what you want.
The fireplaces in the library are "blocked" and can be exploded.
You can then use the parts to create a new custom fireplace.
"Can I export that object in order to modify it with another 3D software and import back to Home Designer Pro? "
I wouldn't advise that, but why would you even want to?
