PhillipsPlans23 Posted July 24, 2023 Share Posted July 24, 2023 I am trying to figure out how to import a Shop Building from one project into another projects site plan. I have an AutoDesk background and I may not be using the right terminology. Link to comment Share on other sites More sharing options...
PhillipsPlans23 Posted July 24, 2023 Author Share Posted July 24, 2023 Chief support had to reset my account. My old account was PhillipsPlans22. I will delete and repost, Thank you for not answering my question... Link to comment Share on other sites More sharing options...
Robborito Posted August 4, 2023 Share Posted August 4, 2023 This is a suggestion only; If you want this shop building as a model then export in the shop builidng file as a 3D Collada file (From 3D window) and then import it similalrly DAE back in to your site maybe? This works for me - you can then manipulate the whole model incl. terrain as one object. Cool. Hint: Watch the scale on importing as DAE file. If it's only needed as a polyline type outline - do similarly as a dwg or dxf file. See reference manual - its free and accurate info and very good. (Usually) Jeff. Link to comment Share on other sites More sharing options...
