BCMike Posted June 30, 2023 Share Posted June 30, 2023 Hi, When I export a PDF it now has thick blurry lines compared to the nice clear versions that I used to get and I can't find a setting that might have changed this. I am attaching an old PDF that looks great and a new version of the same plan. Thanks for your help. Ambiel As-Built pdf 2.pdf Ambiel As-Built pdf.pdf Link to comment Share on other sites More sharing options...
BCMike Posted July 12, 2023 Author Share Posted July 12, 2023 No answers out there? Link to comment Share on other sites More sharing options...
rangerrick Posted July 14, 2023 Share Posted July 14, 2023 Mike, Looking at your pdf's a few things come to mind. I am going to assume you exported these to pdf from Home Designer and not from Layout. Both are on 8.5"x11" but there is a scaling difference between the two pdf's One thing to check when exporting is the DPI. 600 or 300 will give you crisp results, anything less starts to compromise line and text quality. Example attached. Your line weights are very thick in the pdf's you posted. Have a look at the advanced line weight options under File>Print>Drawing Sheet Setup>Advanced Line Options On my screen I don't really see a blurriness, the lines & text are crisp. More of a line weight to scale issue. Cheers, Rick Link to comment Share on other sites More sharing options...
Robborito Posted July 15, 2023 Share Posted July 15, 2023 On 7/13/2023 at 4:49 AM, BCMike said: No answers out there? I have the same problem- and see in the reference manual that it has a lot to do with the scale of the drawings you nominate - but I cant solve my printout problems, I do not understand the logic of this at all, no matter what I try....so I sympathise there - If I get an answer - I will leave it here. Jeff. Link to comment Share on other sites More sharing options...
BCMike Posted August 30, 2023 Author Share Posted August 30, 2023 I have found that if I export a PDF from a layout instead of a plan it is fine. Not always ideal, but a decent work around. Link to comment Share on other sites More sharing options...
