Brick band (on exterior wall) | Home designer Pro 2024
AndreCollin
Hello estimated community !
I would like to decorate the same exterior wall with different brick colors (e.g. in bands)  ,I know, I can do this with the "Pony Walls", but I am looking for some more flexibility.
I would like to draw horizontal bands or blocks with different brick colors.
I have found a way , but highly doubt this is the right way to do it.
1) Display Cross section/elevation view with the exterior wall
2) Design  a Cad "rectangular Polyline" on the exterior wall
3) convert the Polyline (block) into a "backsplash" , the backsplash is the only option that is not "greyed out"
4) Change the thickness of the backsplash to the minimum (1mm) and pick a brick from the material library.
Any advice on best practice for this design issue would be super welcome!
Kind regards,
André
Home Designer Pro 2024
Exemple of brick bands
