Adding deck presents soffit/eave issue?
KParenteau
Go to solution Solved by Rookie65,
When I add a deck onto an area of the design, I am getting a crazy soffit issue where it appears to free float several inches directly above the deck and on the deck roof itself.  I am not sure how to fix this as the other areas/decks do not have this issue.  I have tried rebuilding the roof but that doesn't resolve the problem.  Any suggestions would be fantastic!
  • Solution
Without seeing the plan, I am just guessing. See if you have a ceiling surface over the deck. Sometimes when a deck is made in Pro 2024, the room will be marked as "unspecified." Check to see that it is a room type of a deck and your structure. That may help
@Rookie65 - That indeed was the issue.  I had specified the space as a deck before, but when I moved a couple things around, something got broken.  I had to change it to something else, then back to a deck and then it worked.  I assume this was a glitch that I discovered, but certainly annoying.  Thanks for your input!
