LancasterLinda Posted April 20, 2023 Share Posted April 20, 2023 I am drawing a deck with a center plank that divides the deck planks in two. Both halves of the deck planks are at mirrored 45 degrees. I have not been able to figure out how to divide the deck planking and to get the planks to go in the direction that my client wants. Any advice will be greatly appreciated!! I am using Home Designer Pro 2023. Thanks much, Linda Link to comment Share on other sites More sharing options...
Jo_Ann Posted April 21, 2023 Share Posted April 21, 2023 Use a room divider wall to divide the deck into 2 halves. Open the room dialog box, deck tab, for one of the halves- change the plank direction to 45°. Open the other half,change the plank direction to 135°. 1 Link to comment Share on other sites More sharing options...
Solution LancasterLinda Posted April 24, 2023 Author Solution Share Posted April 24, 2023 Thank you, thank you, thank you, Jo Ann!!! It worked!! Side note - I'm outside of Columbus Ohio....where are you? Link to comment Share on other sites More sharing options...
