moreauj Posted April 18, 2023 Share Posted April 18, 2023 I can't chamfer or fillet CAD segments. I say CAD segments because I'm not sure I know how to differentiate segments and polylines. Sometimes I draw lines and the segments select as a unit, other times it seems not. I believe my chamfer technique is correct: 1) Select segment, 2) Select Chamfer tool 3) Set chamfer size to non-zero 4) Select another segment with a common vertex. Nothing happens, sometimes the first segment remains selected, sometimes the 2nd segment highlights. What am I doing wrong? Thanks, James Moreau PRO 2020 Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 18, 2023 Share Posted April 18, 2023 On 4/18/2023 at 3:05 AM, moreauj said: What am I doing wrong? Expand Probably not setting "Set chamfer size to non-zero", no value = no chamfer or radius, always. DJP Link to comment Share on other sites More sharing options...
moreauj Posted April 18, 2023 Author Share Posted April 18, 2023 Thank you for your response, but you'll notice my step 3) is specifically to set the chamfer/fillet size to non-zero. Intersect/Join seems to work although some strange results depending on geometry and which segment is selected first, but nothing happens with chamfer or fillet. Regards Link to comment Share on other sites More sharing options...
moreauj Posted April 18, 2023 Author Share Posted April 18, 2023 Attached video of behaviour Home_Designer_Pro_2020_Im5ShUfTyj.mp4Fetching info... Link to comment Share on other sites More sharing options...
