Interior walls partially changing to siding Designer Suite 2014
ajluzi
If I reverse layers, the outside of the house has drywall in this area.  If I use the paint can, same thing.   I looked at the old forum, but the commands are not the same.
I have the same issue in the garage where the second floor wall on the interior of the garage is siding, and the rest of the garage is drywall.  If I change the siding to drywall, the rooms upstairs have siding on them instead of drywall.
Thanks for your help,
Armand
Doc2.pdfFetching info...
don't have 2014 to look for you but try using an angled soffit for the angled area not a normal soffit , splitting your screen with a 3d view so you can see what happens to the soffit as you set the front and back measurement, makes it easier to do. but no reason you cant use two like JoAnn said too.
If you are lucky Rich will see this thread and have a look for you ;)
