lawrencelam2000 Posted March 19, 2023 Share Posted March 19, 2023 This is odd- I'm at the point where I'm ready to finalize my framing plans...I noticed that the auto rebuild roof framing tool had spaced my roof rafters at 24" o.c., and I want them at 16" o.c. So my thought was to go into Edit / Default Settings / Framing / Roof and change the default spacing to 16". Which I did. But after going back into the drawing and auto-rebuilding the framing, the framing remains at 24". I looked all through the various nooks and crannies of the program, but the roof rafter spacing stubbornly remains at 24". What am I not doing correctly? Thanks in advance! Link to comment Share on other sites More sharing options...
Garybills Posted March 19, 2023 Share Posted March 19, 2023 Go to build roof (not framing), structure and change rafter space if there instead of defaults. 1 Link to comment Share on other sites More sharing options...
Rookie65 Posted March 19, 2023 Share Posted March 19, 2023 Often even if you change the defaults, you will see a message that says you will need to change individual roof planes. Open each roof and see what the spacing shows there and change as needed. Link to comment Share on other sites More sharing options...
lawrencelam2000 Posted March 27, 2023 Author Share Posted March 27, 2023 On 3/19/2023 at 2:09 PM, Garybills said: Go to build roof (not framing), structure and change rafter space if there instead of defaults. Expand Thanks, that did it! Link to comment Share on other sites More sharing options...
