How do I move a slab downward?
DesignNut
1 hour ago, DesignNut said:
Thank you. I followed your instructions and I was able to pull it down. To be clear, there is no way to set the height of the wall from the floor, you just have to "eyeball it". Is that correct?
In an elevation view you can derail a line and set it at the height you want then pull the wall up to it.
