Turn off - Cabinet sides autofill to wall
ChrishaPotter
I want to place a cabinet between a wall and another cabinet with about 2 inches wall space on each side but it autofills with side molding to the adjacent wall/cabinet. I cannot figure out where in the cabinet details I can make this NOT happen.
Thanks,
CP
If I recall correctly, the ability to turn off automatic cabinet fillers is only offered in the Premier version of the software.  (I don't have the trial installed anymore to double check, but it definitely isn't available in Pro.)
You might be able to use the "Open Front" box shape from the Library Browser for the cabinet instead, and place cabinet doors/drawers as independent objects to fake the look for 3D views though.
Just use the box shape (from the library) as a 2" filler between the wall and the cabinets.  It will prevent them from auto filling.  You can make the box invisible by using the library material> misc> opening(no material)  :)
