MarkHL Posted March 11, 2023 Share Posted March 11, 2023 Hello I am using Home Designer Architectural 2023. I am very new to using the software. I have some interior walls with stacked stone on them. They look exactly as I want them except the stone is the wrong color. Is there a way to change the stacked stone color? If there is I can not seem to find it. Link to comment Share on other sites More sharing options...
Solution Garybills Posted March 11, 2023 Solution Share Posted March 11, 2023 In a 3d view, Select the Adjust Material definition (rainbow) tool, with that tool click on the stone and change the color of the Pattern to the color you want the stone to be and then in the texture tab select blend with texture. Link to comment Share on other sites More sharing options...
Rookie65 Posted March 11, 2023 Share Posted March 11, 2023 You could also download some of the bonus catalogs that are stone based, and change the material to one of the styles you like. Link to comment Share on other sites More sharing options...
MarkHL Posted March 11, 2023 Author Share Posted March 11, 2023 Thanks Gary! I knew it had to be simple but I just couldn't find what I need to click on. Rookie I don't know how to download those catalogs but I will be researching that next. Sounds like a great resource. Link to comment Share on other sites More sharing options...
Rookie65 Posted March 11, 2023 Share Posted March 11, 2023 You will find a lot of great product options and catalogs in there. Strongly suggest that you spend some time reading the instruction manual and using the on-screen "help" tab at the top of each window Link to comment Share on other sites More sharing options...
