Help with unique wall design
mschauer
Go to solution Solved by solver,
Hello,
I'm relatively new to Home Designer, but I like how easy it is to use. I'm currently recreating my existing home, but I've come across an issue. I have a very unique wall cutout that I can't replicate in Home Designer. I attached two pictures of the problem area. In the 3D view, I circled the area that needs to be removed from Home Designer, as it isn't there in real life.
The problem is this wall angles into another wall, if that makes sense. Right now, I'm using a window cutout to create this stacked wall effect. Technically, the half-wall in the 3D image should actually be half wall. But right now in home designer, it is a full wall that has a window cutout.
Furthermore, the corners should be 90 degrees and not that strange angle. See screenshot 2. I've tried everything I could in the software to get it to 90 degrees, but it just won't do it. I think the problem is the floor in that area behind the wall drops down about 7 inches.
Any help would be appreciated. I've attached the plan as well.
plan.planFetching info...
  On 1/24/2023 at 4:21 AM, solver said:
Welcome
It's helpful to know what title (Suite, Pro etc) and version (2018, 2019 etc) you are using. This information is needed to provide the best response.
Please don't comment saying you included that info in your post, and please do not make another comment saying what you have, instead, place this info in your Signature so it's always available by clicking on your user name at the top right of the page, click Account Settings, then Signature on the left.
Doing so makes it always available, and keeps others from having to hunt for it.
And, turn on signature display too.
Many questions have been asked and answered. The Home Designer website is a good place to start your search.
Here is a video about searching the forum: https://youtu.be/dDT6wbrrVRM
Resources for self help:
The built in Help System (always a good place to start)
Expand
My apologies. I realized after I posted this, I should have included that information. I added it to my signature now.
