Single gable roof line over irregular footprint home
raovgarimella
Go to solution Solved by DavidJPotter,
Hi
I am using Home Designer Suite 2023 and am trying to create a home drawing that has an irregular footprint (like most homes) but create a single gable roofline (automatically adjusting wall heights if needed). The automatic roof builder on the other hand wants to make split gable roofs. Is there a way to do this in Suite or do I have to use Arch or Pro and specify roof planes?
Hopefully I can clarify - there are only two roof planes over the footprint of the house with a single gable roof line going from the front of the house to the back. I managed to make the following but it was an awful lot of twiddling around with room heights on the second floor and adding fake rooms to get it right. I am wondering if there is a simpler way in Home Designer Suite 2023. Sorry if I am not able to explain this super technically - I am just a homeowner trying to model a home as accurately as I can to see what the remodel will look like.
I actually solved it in Home Designer Suite by making a rectangular footprint for the house with virtual rooms (invisible walls but asked for roof over the room). Got this nice result without having to pony up another 300 bucks. There is one oddity in the front. If I put a flat roof on the room just in front of the high gable roof and to the right of the smaller gable roof, the smaller gable roof becomes flat and I can't for the life of me figure out how to fix it.
