tapered stairs
BCMike
Go to solution Solved by solver,
Hi,
I am trying to build some deck stairs that are wider at the bottom and narrower at the top. Basically an inverted V shape. I have tried the flare/curve stairs tool but that only seems to affect the bottom two steps and I want a straight taper from the top to the bottom. Is there a way to do this?
Thanks for your help.
