mayall Posted March 16, 2015 Share Posted March 16, 2015 Hi, looking for help with inserting a sketch up sink into counter top, when i insert it does not cut hole in counter top so end up with sink with a counter top in it. Link to comment Share on other sites More sharing options...
katalyst777 Posted March 16, 2015 Share Posted March 16, 2015 What version of the software are you using?If you have Pro, you can use two custom countertops and reshape them around the sink. Otherwise, follow the instructions in this article on creating cabinets around it (the article uses a tub, but the same process applies).http://www.homedesignersoftware.com/support/article/KB-02020/ 1 Link to comment Share on other sites More sharing options...
mayall Posted March 16, 2015 Author Share Posted March 16, 2015 K, using pro, 2015 Link to comment Share on other sites More sharing options...
katalyst777 Posted March 16, 2015 Share Posted March 16, 2015 Great, you might want to add that to your forum's signature so you don't have to remember to add it every time you ask a new question. Link to comment Share on other sites More sharing options...
Elovia Posted March 17, 2015 Share Posted March 17, 2015 If you have Pro, you can use two custom countertops and reshape them around the sink. Hi Kat ... Just to clarify the quote ... One or more holes for tub or sink installation(s) in a custom countertop may be created from a single countertop piece using the break line tool and wrapping the smaller extruded sections around the object to meet back on itself. That said, Pro 2015 provides a "caution" dialog pop up that may be safely ignored since wrapping the custom countertop back on itself in this case is intentional, not inadvertent. Hope this helps or inspires. Link to comment Share on other sites More sharing options...
katalyst777 Posted March 17, 2015 Share Posted March 17, 2015 I am aware that a single countertop can be used, but find the warning annoying enough to justify avoiding it completely by using two. And of course, if you upgrade to Chief Premier, there's an actual tool for countertop holes. Link to comment Share on other sites More sharing options...
mayall Posted March 17, 2015 Author Share Posted March 17, 2015 I have tried both option and must be doing something wrong. when i isert a custom couter top the old disapears but when i start to modify it the old comes back. i have been playing with this for a day know with no glory Link to comment Share on other sites More sharing options...
Elovia Posted March 17, 2015 Share Posted March 17, 2015 Hi mayall ... While a cabinet base is supposed to automatically remove the default countertop when a custom one is placed over it, I suggest that you take the additional step of opening the base cabinet's specification dialog and setting the counter thickness to zero to ensure it is removed ... also delete any molding that may be applied to it. Then draw a custom countertop and shape it as needed to provide the opening for your skp object. Perhaps the following help database article will help: http://www.homedesignersoftware.com/support/article/KB-00983/262/Home-Designer/Custom-Objects/Creating-a-Custom-Shaped-Countertop.html Good luck. Link to comment Share on other sites More sharing options...
mayall Posted March 20, 2015 Author Share Posted March 20, 2015 Elovia This worked great thanks Link to comment Share on other sites More sharing options...
