Centerline Symbol
rdglnd
I do not have Home Designer Pro 2021 but if you will look at dimension defaults dialog-extensions, if there is a programmed way you will find it there. Otherwise you just use text to create a "CL" text symbol and place that text manually over the dimension extension that you wish to annotate as a "center Line". Either way will work.
