LeighG123 Posted October 22, 2022 Share Posted October 22, 2022 Hello When placing a roof, how do you tell it that you don't have an attic? I have trusses sitting on the exterior walls, no attic and no attic walls yet HD doesn't seem to allow that. I have tried making attic walls invisible and turning off the automatic attic walls and then I get this .. a floating roof! What do I have to do to get the roof to sit on the walls ?? Thanks Link to comment Share on other sites More sharing options...
solver Posted October 22, 2022 Share Posted October 22, 2022 8 minutes ago, LeighG123 said: When placing a roof, how do you tell it that you don't have an attic? In this program, you will always have an Attic level, and even an actual home built using trusses for the roof has an attic, it's just not as useable as a stick built roof. For many questions, and this is one of them, attaching your plan file will help someone help you. So many possible settings and ways of doing things, having the file eliminates lots of back and fourth. 14MB size limit. Zip or remove unneeded things like furniture, cars etc. if it's larger. Close the program before zipping and attaching. Link to comment Share on other sites More sharing options...
LeighG123 Posted October 22, 2022 Author Share Posted October 22, 2022 Thank you Eric. Do you have a solution to my problem? I have been googling, youtubing, watching videos, reading message boards rebuild.plan Link to comment Share on other sites More sharing options...
solver Posted October 22, 2022 Share Posted October 22, 2022 17 minutes ago, LeighG123 said: Do you have a solution to my problem? Rebuild the roof. Suggest you leave Auto Rebuild Roofs checked. Link to comment Share on other sites More sharing options...
solver Posted October 22, 2022 Share Posted October 22, 2022 And you might want to do the same with the foundation -- leave Auto Rebuild on. Link to comment Share on other sites More sharing options...
LeighG123 Posted October 22, 2022 Author Share Posted October 22, 2022 Thank you. I now have this and this But the gables are open as is the foundation on the new addition but at least it's in scale and looking better. Should I rebuild the foundation? How do I go about closing up the gables? Link to comment Share on other sites More sharing options...
LeighG123 Posted October 22, 2022 Author Share Posted October 22, 2022 Eric I rebuilt the foundation but it did not put a foundation under the addition. This is a mobile home so I am trying to not physically connect the addition to the home, it will be done as a stand alone structure rather like a deck and 3 season room would be. Perhaps though, that is my problem because I have 4 walls defined in the addition with the one at the house being invisible. Maybe this is not possible with Home Designer and perhaps for my purposes I should delete the invisible wall so that the addition becomes part of the home plan. Link to comment Share on other sites More sharing options...
solver Posted October 22, 2022 Share Posted October 22, 2022 20 minutes ago, LeighG123 said: How do I go about closing up the gables? 59 minutes ago, LeighG123 said: and turning off the automatic attic walls Link to comment Share on other sites More sharing options...
LeighG123 Posted October 22, 2022 Author Share Posted October 22, 2022 Hi Eric. Thanks for the help on this. In the real world I have actually compleated this part of the extension build but am now in the planning stage of a second addition to the far right of the deck which will give me an additional bedroom. What I am doing now is trying to recreate the plan in HD so I can visualize the new addition and it's interior layout. Link to comment Share on other sites More sharing options...
Solution solver Posted October 22, 2022 Solution Share Posted October 22, 2022 Link to comment Share on other sites More sharing options...
LeighG123 Posted October 22, 2022 Author Share Posted October 22, 2022 Eric Wow...Thank you so much for that video! It is not exactly as I have it but it does answer a lot of questions. Your roof over is very nice but since it's a mobile that would be problomatic because with a mobile home they tell you not to make hard connections due to ground heave. My home is on blocks, not lucky enough to have a stem wall or even a slab so my solution was to build it like a self supporting deck which some of it is. I now have this and I can take it from here. Thanks again for the help, sorry if I was a PITA to get started. Link to comment Share on other sites More sharing options...
