ChrisL11 Posted October 12, 2022 Share Posted October 12, 2022 Hello. I'm currently working with Home Designer Pro 2023. I'm trying to have a 2-story exterior wall be visible on the elevation view, but not be a room. When I label the room as a bedroom the roof line is drawn correctly, but when I label the room as attic, the roof line is drawn incorrectly. I've attached a few pictures and any help would be much appreciated. Thanks Link to comment Share on other sites More sharing options...
DavidJPotter Posted October 12, 2022 Share Posted October 12, 2022 Obviously the names for enclosed spaces are not just names, rather they come with preprogrammed attributes, which you have seen and experienced. Read your Reference Manual, practice and observe what your settings cause, good or bad. Watch a help video and then practice what you learned to make sure you have properly learned/understood what you watched. The software is a tool and it is up to you to learn how to use it to obtain desirable results for yourself. DJP Link to comment Share on other sites More sharing options...
