pchristilaw Posted August 28, 2022 Share Posted August 28, 2022 Morning Sorry if I am asking rookie questions. I am just a home user that has used Home Designer Pro to design and build my home and design a shed. My home was built by a contractor based on my designes in HDPro. Thanks for great software. Can I show the Cut list ID's on a 3D ortho framing render or can I turn on the actual dinensions of ALL framing menbers at once? In the attached diagram 1, I have a single member selected. In the red circle I can see the length dimension of that member. 1. Can I show all the length dimensions of ALL member at the same time? or can I display the ID from the Materials list/Cut list - diagram 2, red circle - on the 3D ortho framing render? I want to build this shed myself and this would help with the actual build. Thanks in advance. Paul Link to comment Share on other sites More sharing options...
solver Posted August 28, 2022 Share Posted August 28, 2022 Link to comment Share on other sites More sharing options...
pchristilaw Posted August 28, 2022 Author Share Posted August 28, 2022 Eric. Thank you for the ideas. All of value. Modified the framing as suggested. Extenal materials will be verticle Board and Baton to match my home. Yes windows above door and in back wall. 72"x80 " double door. Studs 16" o.c. only because that is what my home was built to. Understand I can not turn on all the dimensions at once and can not add Cut List ID's to any rendering. Should be ok with the cut list to build this. Thought it would make it easier with drawings that had dimensions by member. Any other thougths you have would be appreciate. Cheers Link to comment Share on other sites More sharing options...
