RobtWJ Posted August 24, 2022 Share Posted August 24, 2022 I imported a DXF file from Floor Plan Creator into Home Designer Pro 2021. As soon as I click on anything the walls disappear and I can't trace the walls. Any thoughts? Is it on a different layer? Thanks Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 24, 2022 Share Posted August 24, 2022 Such imports usually come in on the "Default CAD" layer. You should position one of the corners your import at or near the "0-X and 0-Y" position in plan view then "Lock" the layer in the plan view's "Display Options" dialog. Then you should be able to trace without interference from the import. DJP Link to comment Share on other sites More sharing options...
