mdag28 Posted June 16, 2022 Share Posted June 16, 2022 Good afternoon, I am trying to change the direction of the brick material on one side of a knee high wall. It has the bricks stacked on their short edge, but it should be stacked on long edge. I made it out of a base cabinet. I tried using the Adjust Material Definition command, but it adjusted it for the entire wall. I have the same issue for the vertical separation for the counter made adjacent to the outside wall. Is their a way to adjust one side of the wall only? It needs to match the direction of the fireplace brick. It seems like one of the faces is oriented differently than the other. Covered Patio 21x30.zip I zipped the plan file and attached it. Thanks for looking at my post. Michael Link to comment Share on other sites More sharing options...
solver Posted June 16, 2022 Share Posted June 16, 2022 Make a copy of the brick material, change the direction and give it a new name. Link to comment Share on other sites More sharing options...
mdag28 Posted June 16, 2022 Author Share Posted June 16, 2022 I tried that and it still leaves me with one side that isn't oriented the right direction. I copied and changed to 90 degrees. It is the back of the "cabinet" that is oriented differently than the rest of it. Link to comment Share on other sites More sharing options...
solver Posted June 17, 2022 Share Posted June 17, 2022 You might try a soffit or slab or shape from the library instead of a cabinet. Link to comment Share on other sites More sharing options...
