BigAl123 Posted June 4, 2022 Share Posted June 4, 2022 terrainSpline.plan Home Designer Pro 2022, build 23.4.0.123x64 Spline Terrain Curb not working as expected. This has been asked before and there is a training video that clearly demonstrates the spline creation but I can't get it to work. Everything I've tried ends up with separate line segments that act independently. Please see the attached plan. I did get in to work a while back so I know it's possible but for some reason I can no longer get the results I'm expecting. Has anyone found a common cause why some users have had the same issue and then suddenly solved the problem? The solutions people have posted lack some details for me to be able to solve this on my own. Also - I should probably update to the latest version but I'm in the middle of several projects and I can't risk it just yet. I'd appreciate any ideas. Alain terrainSpline.plan Link to comment Share on other sites More sharing options...
Solution solver Posted June 4, 2022 Solution Share Posted June 4, 2022 Link to comment Share on other sites More sharing options...
BigAl123 Posted June 4, 2022 Author Share Posted June 4, 2022 Thanks Eric I figured it out from your video. In order for this to work, I needed to have "Connect CAD Segments" enabled. Right hand menu, sixth item from the bottom. That wasn't obvious to me. Maybe it's just me but I think that any spline tool should automatically suggest enabling this feature on or simply turn it on and advise the user that it's now enabled. Thanks again. Alain Link to comment Share on other sites More sharing options...
