Rotating an architectural block
kadi31106
I need to rotate an architectural block but I need to do it on the Z axis. The easiest way I would think to do this is in a cross section view but the rotation handle only appears for X and Y rotations. For clarification, I'm designing a custom dog ramp. I "built" the entire ramp portion flat to the "ground" just as I would in real life. Now i'd like to tilt the entire block that makes up the ramp to find the right slope. Any help or suggestions would be great. Thanks!
When posing questions here you need to add what software and its version you are using. Different titles and versions have different capabilities. Generally speaking I do not believe what you wish to happen can be done in any Home Designer software title or version but if I knew what/which you do have I can be more certain. Once I know your software title and version, I may be able to do was you wish using Chief Premier and then send it back to you, if you will post a copy of your .plan file, let me know, please.
