THEVAX Posted May 3, 2022 Share Posted May 3, 2022 I'm having a difficult time figuring out the correct wall type to use and the order of operations to build this front porch. Below is a list of elements. 1) Cantilevered framing. The upper half is continued siding from the main structure and the lower half is wrapping in 1 x 12 to look like a box beam. 2) Columns supporting the faux beam 3) Brick Piers - "L" shaped 4) Railing and decking Image 1 is a general idea of what it should look like, I put this together with a series of individual elements. I feel like there is a more efficient way to build this. Image 3 is an attempt using ponywalls and raising the floor to what is now the bottom of the faux beam. I've also included a photo of the actual house, note my model has more columns. The other component to this is that the porch ceiling is about 6" shorter than the adjacent rooms which is throwing off my roofline. I appreciate any advice you are willing to offer. Jason Link to comment Share on other sites More sharing options...
THEVAX Posted May 5, 2022 Author Share Posted May 5, 2022 Hi Eric, Thank you for the advice and the resources. I will dig a little deeper into those and try to frame a more specific question if I can't find a solution. Link to comment Share on other sites More sharing options...
Jo_Ann Posted May 6, 2022 Share Posted May 6, 2022 This is a complicated design for a new user. Too many elements and settings to try to explain, but it can be done. Practice and experience will get you better results. Keep working on it. Link to comment Share on other sites More sharing options...
