Add filler pieces at side of cabinets
EdwardJohnAllen
Hi
I am creating a full wall of cabinets for a "TV / fire" wall in a lounge and wanted to have a 5" filler (scribe?) at either side of the room.
Is there a good way to do this please?
Many thanks in advance
Edward.
Using Home Designer Architectural 2022
3 minutes ago, solver said:
I believe David gave you the answer in your other thread -- create a cabinet with a blank front and use it as your filler.
You can save it to your Library for reuse.
He gave one answer. I suspect there might be other perhaps more elegant ones out there....
With Pro you could create a single cabinet like this, but for a filler, a blank fronted cabinet is the way to go.
