jKaufmann Posted March 5, 2022 Share Posted March 5, 2022 Since "Primary Wall Side" is used in specifying how a wall's dimensions are done, I was sure I could find out how to specify which side of a wall (interior wall, if that matters) is primary, but can't find it in the Reference Manual or any of the videos. Can someone point me to an answer? - preferably with treatment of a wall with an unfinished side? Link to comment Share on other sites More sharing options...
solver Posted March 5, 2022 Share Posted March 5, 2022 I don't know of a setting for primary wall side. What are you wanting to do that's not working? What dimension tool are you using? An annotated screen capture would probably help. Link to comment Share on other sites More sharing options...
jKaufmann Posted March 5, 2022 Author Share Posted March 5, 2022 Thanks for your suggestion. (Sorry it took me a little time to comply.) I hope that, after a few passes to clean up, the question is clear. I'm capturing as-built dimensions of a 1st-floor kitchen. Between stairs coming up from floor 0 (roughly identical stairs connect floors 1 and 2) and kitchen cupboard is a space where pipes and laundry chute go from floor 0 to floor 2, chimney goes from floor 0 to roof. That space is unfinished (so presumably not primary side of wall). When I try to capture inside dimensions, HD insists on dimensioning to inside (presumably because inside is primary side?) of cupboard wall and does not pick up the dimension from the outside of the cupboard wall to the kitchen interior wall. I've searched the manual, tried rebuilding the walls, etc. I can't see how to specify one wall side as primary. Thanks again. Link to comment Share on other sites More sharing options...
Solution solver Posted March 5, 2022 Solution Share Posted March 5, 2022 Link to comment Share on other sites More sharing options...
jKaufmann Posted March 6, 2022 Author Share Posted March 6, 2022 First let me say what a nice thing you did, taking that time to help solve my problem (and offering more time if I could not get it worked out). The key was the Reverse Layers tool, which switches primary/secondary wall sides. And now, after playing with it, I think I understand the conceptual point of it: The user gets to define "Primary Wall Side" by whatever criteria are needed for the job. For example: need one side with drywall (primary), and the other side bare (secondary)? - just define it that way. And so I did, finally. All good now. Thank you! Link to comment Share on other sites More sharing options...
cabinetrep Posted March 7, 2022 Share Posted March 7, 2022 I read this solution and went looking for the reverse layers tool. Found it - and then lost it when I tried to re-locate it from the bottom of my screen to the top. Can you tell me what toolbar this tool is on, please? Thanks Link to comment Share on other sites More sharing options...
