NivRajan Posted February 14, 2022 Share Posted February 14, 2022 Hello. I'm Using Home Designer Pro 2019. I'm trying to build a two storey extension to a house. (Please see attached photo of a cross section sent by an architect.) The terrain is sloping, and Ive created a flat area and built the pool. Now, I'm not able to build the lower floor at a level *Below* the terrain level. The first floor has to be at the level of the deck area. I've attached a pic of the work I've done so far, and another where I want the extension structure to come. Can someone please help me figure out how to lower the terrain such that I can build the structure. I'vve tried lowering the ground, adding new elevation regions, nothing is working... its only creating bigger messes for the larger plot, and the already built structure. Would appreciate any and all suggestions as to how to excavate that bit of terrain without it messing up the rest of the landscape (and please ignore the obvious errors in the main building- yet to complete work on it!) Link to comment Share on other sites More sharing options...
solver Posted February 14, 2022 Share Posted February 14, 2022 3 hours ago, NivRajan said: Now, I'm not able to build the lower floor at a level *Below* the terrain level. What is stopping you? Link to comment Share on other sites More sharing options...
NivRajan Posted February 14, 2022 Author Share Posted February 14, 2022 The terrain is not letting me build a floor below the deck. At best I'm getting a walkout basement, but not one which is fully open. Link to comment Share on other sites More sharing options...
solver Posted February 14, 2022 Share Posted February 14, 2022 It sounds like the terrain is not preventing you from doing anything, it's just not in the correct place. You need to lower the terrain where the new building will sit. I'm not much help on terrains as I only use very basic ones in my models. Suggest you attach the plan file (close Pro first) and maybe someone will take a look. Link to comment Share on other sites More sharing options...
