AETAET Posted January 11, 2022 Share Posted January 11, 2022 Hello, Anyone knows how to create this attic wall adequately! I've tried everything and failed! Thanks Attic wall.plan Link to comment Share on other sites More sharing options...
solver Posted January 11, 2022 Share Posted January 11, 2022 What do you want there? Link to comment Share on other sites More sharing options...
AETAET Posted January 11, 2022 Author Share Posted January 11, 2022 simply to connect the 2 roof planes with a wall and not have it open to the exterior! The interior is one open room and doesn’t have a flat ceiling. Link to comment Share on other sites More sharing options...
solver Posted January 11, 2022 Share Posted January 11, 2022 See if this helps Link to comment Share on other sites More sharing options...
AETAET Posted January 11, 2022 Author Share Posted January 11, 2022 Hi, thanks for the link. I am glad I am not the only one having issues with attic walls! But this doesn't fully solve the problem. This attic wall doesn't get generated automatically for some reason. If I create it manually on the attic floor, set it an attic wall and bump the lower roof into it, then I get this: If I activate the "Roof cuts wall at bottom, then I get this (the upper roof actually cuts the wall at bottom. I want the lower roof to do that): The "lower wall type if split by butting roof does nothing!" If I play with it manually, I cannot get the ceiling right: The software should be able to handle this simple task! Link to comment Share on other sites More sharing options...
