Sheski Posted December 25, 2021 Share Posted December 25, 2021 (edited) The problem that you see in this picture has been reported several times in this forum. However, no working solution has been given that does not generate extra walls in the attic space. I want to use that space as extra storage and room for the house's mechanicals. I do not want extra walls. Dragging the adjacent wall creates these extra walls. I already know how to use these forums, so please don't repeat that information. Thanks, Jerry 2305 Tall Roof.zip Edited December 25, 2021 by Sheski added plan file Link to comment Share on other sites More sharing options...
DavidJPotter Posted December 25, 2021 Share Posted December 25, 2021 You toggle up to the <A> or attic level, turn on the "Reference Display" view so you can clearly see where to manually draw your attic gable walls that are missing, easy-peasy and Merry Christmas! DJP Link to comment Share on other sites More sharing options...
Sheski Posted December 26, 2021 Author Share Posted December 26, 2021 How do I delete the unwanted walls that are created when auto-build roof is active? Please see the included picture and attempt the fix in the attached file. Thanks, Jerry Link to comment Share on other sites More sharing options...
DavidJPotter Posted December 26, 2021 Share Posted December 26, 2021 The software is hard pre-programmed to recreate attic walls automatically, your ONLY choices are to either make the auto attic walls is to make invisible or manually draw or redraw them. DJP Link to comment Share on other sites More sharing options...
ajblassic Posted January 30, 2022 Share Posted January 30, 2022 Jerry, did you figure out how to fill in the walls? I’m having the exact same problem. Thanks Amy Link to comment Share on other sites More sharing options...
