Roof is auto build with an angled soffit
wazzubrad
DJP,
Thank you. Unfortunately, it looks like I have created multiple issues and I am not sure how. I can't seem to get my roof built without the 2nd floor walls disappearing and creating a really weird 3D view. I attached a photo of my settings and also photos of before roof is built and then after.
Kbird1,
Yes, the roof is a 4/12 so I wanted to makes sure we had room for insulation in those areas by creating a taller heal. I tried to attach the plan and begins to upload but finishes with notice that "No file was selected for upload", /geesh.
-Brad
not sure it is your disappearing walls issue but check your Ref.Manual for Energy heel (page 447 in mine) the setting must be minimum of 8" , I usually set it to 10" as you need 2" above the insulation (R40) for airflow out of the Soffits too. (HD does not model the insulation baffle as far as I know but a note on the plan would suffice.)
if the Plan file is over 25mb it wont upload, so zip it or delete stuff from the plan until it can be posted if needed, eg the terrain. ( use a copy of your plan , not the original)
