wazzubrad Posted February 15, 2015 Share Posted February 15, 2015 Home Designer Pro 2015 I am trying to determine the best way to add a 2nd level to the home I am designing. Here is the process I am using; * After creating the entire 1st floor layout, I go to "Build -> Floor -> Build New Floor" * It gives me the options "Derive new 2nd floor plan from the 1st floor plan" with a sub option to "Step floor/ceiling elevations to match existing floor", and "make new blank plan for the 2nd floor". My second floor plan walls (ext & int) will not necessarily mirror the level 1's floor plan. The problem I am having is when the new floor is created using "make new blank plan for the 2nd floor" and I am working on "Floor 2", the exterior walls from level 1 are shown on level 2. Do I delete these walls and create new Exterior walls and begin my plan? If I don't, it makes it rather confusing as to which new exterior walls I have drawn as some sit directly above the level 1 walls. I have added a photo to help explain. I hope I have been clear enough. If not, please let me know and I will clarify! Thank you, -Brad Link to comment Share on other sites More sharing options...
Jo_Ann Posted February 15, 2015 Share Posted February 15, 2015 Most likely, the existing walls you are seeing on floor 2 are attic walls. Draw the new exterior walls over them. Turn on the floor reference to see where the floor 1 walls are located. After drawing new walls (that exist over floor 1 walls), right click each wall and select 'align with wall below'. Link to comment Share on other sites More sharing options...
wazzubrad Posted February 16, 2015 Author Share Posted February 16, 2015 Thank you. Your response gave me an idea. I deleted the roof using "delete roof planes" and all of the walls that were showing up on level 2 disappeared. This will make it much easier to build the 2nd level walls. I also turned on floor reference as you suggested to see the walls on Level 1. Thanks! Link to comment Share on other sites More sharing options...
