jmyers Posted November 6, 2021 Share Posted November 6, 2021 I have been unable to figure out the following: 1. How to create twin windows (double windows). I'd like to have a mulled twin 3/0-5/0 window. Are there any other options besides placing two 3/0-5/0 windows beside one another or placing a 6/0-5/0 window in the wall? 2. How to create an exterior entry door with sidelites on each side. Link to comment Share on other sites More sharing options...
solver Posted November 6, 2021 Share Posted November 6, 2021 Chief has mulled windows, Home Designer does not. 59 minutes ago, jmyers said: How to create an exterior entry door with sidelites on each side. ??? Look in the Library, or place a door and 2 windows. What are you wanting that that does not do? Link to comment Share on other sites More sharing options...
jmyers Posted November 6, 2021 Author Share Posted November 6, 2021 I have placed a window beside my door and that looks great on the floor plan and exterior elevation view. However, it creates an issue with automatic exterior dimensions. The dimensions shows measurements for a window, which is actually inaccurate if the intent is to use a door/sidelite mulled unit. Link to comment Share on other sites More sharing options...
solver Posted November 6, 2021 Share Posted November 6, 2021 49 minutes ago, jmyers said: The dimensions shows measurements for a window What do you want your dimensions to look like? Link to comment Share on other sites More sharing options...
jmyers Posted November 7, 2021 Author Share Posted November 7, 2021 On 11/5/2021 at 11:49 PM, solver said: What do you want your dimensions to look like? I do not want an exterior dimension line to the middle of the sidelite (window). I'd like for the dimension line to go to the middle of the exterior door only. Link to comment Share on other sites More sharing options...
solver Posted November 7, 2021 Share Posted November 7, 2021 56 minutes ago, jmyers said: I do not want an exterior dimension line to the middle of the sidelite (window) Remove it then. You can remove or add to a dimension string. Link to comment Share on other sites More sharing options...
jmyers Posted November 8, 2021 Author Share Posted November 8, 2021 Am I able to delete a portion of the string? I'd like to keep the rest of the dimension string. Link to comment Share on other sites More sharing options...
solver Posted November 8, 2021 Share Posted November 8, 2021 Watch a video or 2 on dimensions. Link to comment Share on other sites More sharing options...
jmyers Posted November 8, 2021 Author Share Posted November 8, 2021 Thanks Eric! Link to comment Share on other sites More sharing options...
rocketseeds Posted November 11, 2021 Share Posted November 11, 2021 Thanks! reading the replies helped me. Link to comment Share on other sites More sharing options...
