turning design by 45 degrees
TERRYTAYLOR
Yes, but is not a good idea to do so. Maintaining the "North/South" of your plan view will  serve you better than turning it at an angle. That is what the magnetic "North Pointer" tool is for, so you don't then need to turn the structure, you turn, instead a "North Pointer" instead indicating magnetic North relative to the structure.
